Hello to you all again.....When I am driving, on coming to a junction the engine revs fall to low, and the engine cuts out, which is rather un-nerving..Has anybody any idea as to what causes this and what is the way to cure it...My car is a 1995 LS400 mark3............... Thank you all again...... Roy.
4 hours ago, Tinonline said:
Could it be the Maf sensor?
if it's like a Merc you can unplug it and it'll run albeit a bit rough and without full power to get you home.
And I should add, this is a way of testing the MAF as the motor might run roughly but it won't stall.
I gather it can be a fuel pump or fuel pump relay breaking down but I think this is when the pump is hot.
I'd be surprised if it's the throttle body.
Worth checking all air hoses and associated clips.
