Alucard7002
LS430 Beat Sonic MVA-23, double DIN fascia, Alpine ilX-700
Hello all,
Looking to put original radio back into my 430.
P/O fitted this lot and while it works the user interface and overall look of the things doesn't appeal to me.
Make me a sensible offer considering all of this kit new would cost over £800
Or if you have the original ML Radio/CD changer, fascia (CD cover, switch backing and cubby hole) I'd consider a straight swap, mine is an '01 premium pack with ML and nav :wink3:
Alpine radio is on Gumtree
Beatsonic adaptor will be available as soon as the replacement ML unit arrives in the post (hopefully this week!)
Fascia NLA
  • Similar Content
    • By LSE
      I just recently bought a 2001 LS430 and It’s got an issue with the front suspension dropping usually over the course of 3-4 hours. The front end of the car is nearly on the floor when I go to it after leaving it overnight.
      When I got the car I had an issue where the rear of the car would be stuck in the high setting so I done a Battery reset which sorted the rear suspension but the fromt still keeps dropping. Although when I press the high button the car will raise and get stuck in the high position again so will have to do another Battery reset to fix
      Also something else I’ve noticed that when pumping the suspension up when it’s low, it takes about 5-10 minutes and the pump will kick on and off even though the front suspension is low. Is this normal?
      also any ideas on the suspension dropping? I have checked the shock absorbers and can’t see any moisture anywhere or any obvious leaks  is there anything else I could check?
      Appreciate any help because I haven’t had the car long and hope to get it sorted. I like the car but the suspension is sending me mad
    • By jonthetourist
      So I am hearing a tiny rumbling noise on the car. Hear it best at about 25mph with no revs. I am thinking wheel bearings, maybe driveshaft, and then the thought occurred that I am due to change the tyres and I should do that first.
      Call my usual supplier and they quote me £565 for 4 Goodyear Eagle F1 Asymmetric 3s. Including 4-wheel alignment? No, that's separate. Time to check the price is right so look online and find Mytyres will supply them a fitter for £108 each, and the fitter will put them on for less than a tenner each. Total saving £100. The 3 is a failry new tyre, so it's not old stock, I am confident. Put the order in.
      Online tracking tells me they have been delivered Friday afternoon. Call the fitters to book an appointment. "We haven't seen them". Call the delivery company who check the signature and then the driver's log. He has only delivered them to another tyre place nearby. They will "try and get them back and redeliver".
      Watch this space.
      Jon
    • By Smoother
      Hi, I'm new here, and as such I am restricted to posting in new members only.  So if a moderator would like to place it appropriately, that would be cool.
      I recently decided to tackle my timing belt.  at 185,000mi (1st. one was around 90,000) it was time.  I know there's a lot of leeway regarding miles, but age, usage,  and environmental conditions can age rubber products differently, so I didn't want to push it, or i'd be pushing it, literally.
      I'm no mechanic.  But I have a few tools, and I regularly study at the university of YouTube.
      Basically it was quite easy (and bear in mind, when I first watched others do it on YouTube, I said "no way am I up to that ".  Well it turns out I was.  You may be too.
      Here's the stuff that caused me trouble, that isn't mentioned by others:
      1. Try and do it all on the same day, which means, have ALL your new parts there already.  That way it will be fresh in your mind.  Don't let a few days elapse between disassembly and assembly, like I did.
      2.MAKE METICULOUS NOTES ABOUT WHICH BOLTS/STUDS GO WHERE AND WHAT THEY DO.
      3. Take lots of pictures, and make sure they are clear detailed pictures.
      4. Work with a lot of light, its quite dingy down there in a november garage.
      5. Dress warmly (if appropriate)  cold will make you take shortcuts.
      6.  Take your time when warming the car up, as well as checking for leaks and funny sounds, you need to make sure the water system is completely full.  Just filling it up isn't enough.  I can't explain what happened to mine, but I think I had air around the water pump, so it couldn't pump.  So make sure your radiator is getting hot.  Make sure the top hose it very hot and the bottom hose is cooler.  If the fans come on and the air they move is cold, you have air in the system, and air in the radiator, even if you did just fill it to the top.  Take your time and confirm the system is circulating hot water.
      Let me 'splain. Item 2 above. For example, the first thing to go back on is the new water pump.  It's got a lot of bolt holes in it, but when I picked up the old pump for reference, it only had 2 bolts in it. Huh??!! how did that happen?  Looked all around for the missing bolts but none could be found.  Through a painful process of trial and error, and putting the tensioner system on then having to take it off again(complete with re setting the tensioner unit), I finally figured out what was going wrong.  As you are pulling the various bits off in sequence, you don't notice that a particular bolt you remove, is holding on more than one device.  Example, if I remember right, there's a small black plastic cover that comes of very early in the process.  At least one of these bolts also fastens the water pump; the last thing you take off.  That explains one vacant hole on the water pump, because the bolt was in the plastic shield. There were several other "dual purpose" bolts like this.
      Seriously that was the hardest part.
      Other notable events:
      Bumping the 22mm harmonic balancer bolt? prop up the cheater bar, YouTube style, and bump the starter. Easy Peasy.
      Lining up the cams and belt, a little fiddly but very doable, check your work 6 times especially the little mark on the cam shaft pulley, its visible from underneath.  Try and get the Mitsuboshi (sic) or other belt with timing marks printed right on the belt.  Makes life so much easier. (curiously the old belt had these marks, but the dealer mechanic who changed it, didn't use them ) Yes, they were the right marks, I checked.  And yes, just like everyone else, the old belt looked pristine (but it makes no sense to put it back in, does it)
      Retightening the 22mm crank bolt took some thinking (no impact gun and no assistance)  I took the old serpentine belt and locked it around the harmonic balancer by pinching it against itself.  Then i took the loose end and wrapped it around the power steering pulley anti clockwise.  then I put a cheater bar through the loop and wedged the end in a strong place above the alternator.  With my left hand I held tension against the other end of the cheater bar, and cranked as hard as I could on the crank bolt with a long 1/2" torque wrench.  Did i reach the specified torque? hard to say, cos my torque wrench doesn't quite go that high, but I was close, as I was passed the "click click", AND I used some thread lock.
      When I flocked up and had to remove the new tensioner pulley, I had to remove the harmonic balancer AGAIN, having just almost popped a blood vessel tightening it.  I used the serpentine belt again.  This time I wrapped it around the A/C pulley and found a different place to anchor the cheater bar, and another vein to almost pop..  Why not just bump it again? I didn't want my timing marks to move, as I'd lose site of them; and when the tensioner came off I was in danger of the belt jumping a tooth ( it likes doing that when there's no tension on it, ask me how I know)  To sub for the tensioner while I was discovering ALL the bolts for the waterpump, I used zip ties to cinch the belt up against both cam pulleys.  This took all the slack out of the belt so I was ok on the cam pulley, but I did triple check ALL marks when it was all back together, AGAIN!.
      So if you think you're up to doing your belt, let me tell you, its a lot easier than you think (I've never done a timing belt before on anything)
      Total cost £227  (water pump, timing belt, idler pulley, tensioner pulley, tensioner, thermostat, serpentine belt, AND radiator)  Good to go to at least 280,000mi)
      Oh, and for £28 more, I added a trans cooler in front of the condenser.  Whose idea was it to cool the tranny with hot water from the engine? The perfect time to do the rad and the cooler.
    • By Alucard7002
      Hello all,
      Been looking for ages for a Mystic Gold with beige interior on a Y plate... I know, asking for hen's dentists. In the end thanks to a weekend in Amsterdam with my brother along with EU data rules and eBay for android I bought this instead!
      2001 Y plate LS430 in Blue Onyx with the Ecru (beige) interior.
      Fixed a few niggles and have a few more to fix too. Nothing untoward and nothing I'm not afraid of tackling, I've rebuilt engines and welded up cars many a time in my years on this planet.
      Had to bodge the offside rear ride height sensor as the arm snapped on my drive home after buying it! Fixed now with the proper part.
      Need to get my LPG conversion going sharpish as I'm averaging ~12mpg with my commute.
      Also need to get used to filling a 90l petrol tank vs 68l LPG tank - price difference is quite drastic for a full tank!
      Polished and clearcoated the headlights as they were very yellow and let the car down, then put a HID HB3 kit in the main beams and the fogs (I do a lot of driving on the fens so lighting up the road with daylight is a must!)
      The little light lenses next to the foglights are not used on my LS for some reason, perhaps a JDM/US market thing. I am planning on putting some LED 382 bulbs in and use them as DRLs
      Also had a play with techstream and a £14.99 cable from eBay. All worked and told me I have two dead O2 sensor heater circuits on the pre-cat sensors. Will need to replace ASAP.
      All for now, shall report back once I've found the cause of the slight knock on the nearside front and put new front discs and pads on her.
      Cheers
      D
    • By ScousePaul
      I noticed that my A/C on the 430 wasn't blowing cold recently when we had that warm spell. The A/C was regassed just a couple of months ago by Lexus when I had it serviced - not sure if they test functionality at that time or not.
      Was going to get them to have a look, but then had a weird experience today where the A/C selection was just greyed out on the LCD screen. Couldn't enable or disable it and the temperature controls didn't function. After a short while though they sprung back into life. Still no cold air, but certainly something odd going on. Anyone come across anything similar? Suggestions for what to check before I get it looked at?
