A960e and A760e gearboxes interchangeable?
el_bandido
I've been looking at the solenoid diagrams for these two boxes; I'm considering a 3gr-fse swap into my IS250. The solenoid activation is identical in both gearboxes, though the clutches used are not. Would I be correct in thinking this means the IS250 ECU would control an A760e transmission, if I was to drop it in with the 3GR-FSE? I know that the IS250 ecu will happily deal with the 3GR-FSE head and block, using all the other parts from the 4GR-FSE that it originally came with. The main reason for asking this is the strength of the a760e box appears to be better than the A960e.
