Morango
IS200 1G-FE Engine map
Has anyone got a basic 1G-FE engine fuel map. Scoured the entire internet with no luck. cheers
Try Lexus, these ECU's are self learning, so you should never have a problem with it being standard/basic
Nah i need one for turbo mod on a standalone ecu. Just a basic map to get the thing started on
Try to find another i6 with same displacement and compression and with coil packs. Should work right? But you probably need to ditch the ETCSi throttle body first.
That's easier said than done. I have a 1jz map I could probably use if I fiddle with the settings. O2 sensor should bring to more or less the right place. And I just need a base map so I can start the thing and finish wiring up the ecu. Once that is done I will take it to the tuners.
I should be fine with the standard TB but will change to a log manifold and probably use a 1jz TB I have eventually.
Cheers
