eBay says 275 people bought them so they can't be that bad . I would say give it a try and it is not ok you can always return it .
When mine went on the gs450 i have bought some osrams from http://www.autobulbsdirect.co.uk/ for about £60-70 i don;t remember exactly .
I had to replace mine and found it very awkward on the 430 - had to remove the airfilter box and move coolant bottle out of the way to gain access - maybe someone with smaller handles and nimble fingers might be able to fit it without problems.
On 10/21/2017 at 10:46 AM, Zotto said:
No, but be careful to have all electric circuits off, as Xenon works with high voltage.
I Installed them earlier and it was a five minute job! I recommend that eBay seller too everything was spot on..
On 03/11/2017 at 5:50 AM, Fireblade1 said:
not to impressed with the lights on my 2010 gs450 I was thinking of replacing with osram night breaker's has any one used them or can anyone reccomend any bulbs which are a decent upgrade over the standerd bulbs
I'm thinking the same as this.
My bulbs are very disappointing, I'd say bordering on inadequate (I've had brighter non-xenons).  I assume Xenons dim over time?  On a 10yr old car with 120k I guess they'll not be operating like newer bulbs?
Malachy did you see an improvement in your new bulb?  Are they tricky to fit on a GS450H?  I replaced parking lights recently and they were a nightmare to fit!
My son has the Osram Nightbreaker Unlimited Halogen H7 bulbs and they are very good. Almost too good in fact. Oncoming cars WILL flash 70% of the time even if headlight adjustment is right.
No it made fek all difference with new bulbs plus I had my lights restored like new as they were gone cloudy and they are the same....😦😦😦
Malachy, how you restore head lights? Cleaners, or sanding down and clear coat? Mine gone at top, so not interfering with light, but starting to spoil looks
6 minutes ago, cpk said:
I have the same problem.
A touch of "Mother's plastic polish" gets rid of the haze but only for a couple of months.
The haze is caused by UV radiation oxidising the plastic. To get it to last any longer you need to polish it up and then put on a UV-resistant protective top coat.
Autoglym headlight restoration kit, a drill and a handful of brave tablets :biggrin:
Will try a cleaning kit first then, although I think it's glazed a bit too much, as lots of very small tiny crack lines showing in the hazy areas, perhaps its a prior coating giving up the ghost.
