Hi
I'm new to the board. Recently someone took a crow bar to my '93 Lexus LS400 which was much beloved. Reprobates. Anyway I've been looking around and there's a specific look I'm trying to find. It's def not the Mk5 I think as it has the straight headlight. I think it might be DHP? Perhaps you could let me know how difficult this might be to achieve/find? Picture below. Thanks in advance.
The car in the picture looks like a MK3 with DHP wheels..
^ And that is the reason I love DHP wheels
The Mk4 has a restyled front end:
The car is an early ls400 - 1989 - 1992 mode therefore a mark 1/2 - the wheels are not original for this car/year and are from a mark 4 (1998) model - hope this helps
the Mk3  (  from 1995 )  doesn't have the lower fog light setting
two very beautiful cars ............  :winkiss:
What I like about my Mk2 (1993) is the crease in the styling and the low Fog lamps which can be turned on with just the sidelights.
I had a Supra Mk 3 which had similar and around that time (or maybe somewhat earlier) it was  cool to look a bit like Nightrider !
Bit old for "cool" posturing now, but they are there if I want.
Thanks for your replies. Much appreciated. I think on balance I'd say the 1995 swings it for me, if the article is accurate.
But seriously, most importantly...
Why can't I find a black one??? :)
I did find a Blue one though.
1997. 97,000 on the clock. 3 owners, couple of 'car park dings'. Was in an accident and had the bonnet, bumper and headlight replaced. Don't know if it's DHP. Can anyone tell me the right questions to ask?
Thanks in advance...
Not many about, but, the dark 'green' color looks black under many lighting conditions & the green shade is very dark, nice color I've had one (now black), if you see one advertised best go look & make your mind up after you've seen one (maybe you have), as has become clear not many for sale worth having these days.
I believe that the DHP (Dynamic Handling Pack)  was only available on the MKIV, the model with touchscreen Sat Nav and 1 piece headlamp/sidelight.
There is a post on here sometime ago confirming dhp wheels, maybe not suspension, were an option prior to the Mk4
1 hour ago, cruisermark said:
This one has early ls430 wheels - it’s not dhp
Yes agreed, thought I had quoted an earlier post were it was thought dhp wheels we’re Mk4 only
It can prove very difficult to determine if the car is DHP spec or not, the ride height was lowered 10mm so near impossible to check just by looking at it, the road springs are also no longer available so may have been replaced in the past with standard ones.
The DHP wheels are 17" as opposed to the standard 16" ones but again these are a popular upgrade and may have been obtained and fitted by a previous owner.
If you come across one with Radar Cruise Control it will be a rebadged imported JDM Celsior as this option was only available in Japan.
Good
hi all,one very easy check to see if your ls400 has dhp,the front grill is colour coded
Agreed, if it’s the original item.
Here is some info regarding DHP option.:
  • Similar Content
    • By Keynun
      Hi guys
      Just started my LS400 MK4 1999 and it now makes an extremely loud whining noise. This occurred quite randomly as it was not making noise the other day.
      Any ideas what it could be?
      The noise gets worse as the RPMs increase and the pitch gets higher. Power steering seems to be working fine and have not had battery issues as of yet.
    • By Argyll
      Can anyone advise on how best to get confirmation of the first date of registration,I purchased a LS400 which was registered in the Netherlands on I believe 20th October 1995 from a record in the service book however DVLA insist I obtain a letter from a owners club registered on their web site and it appears no Lexus club is,this is all that's preventing registration. Any information would be most welcome.
      archie
    • By Tinonline
      A few months ago at 75k odd miles I replaced my spark plugs from my mk4.
      I couldn't see any evidence of past replacement and was puzzled by very worn plugs bearing the NGK brand in pale blue. They looked old. I did a write up; that's in the how to section.
      What I put in were Denso plugs and that's what I'd expected to remove. All the mileage checked out.
      However, having a trawl through the handbook I spy that original fitment listed as Denso SK20R11...and NGK IFR6A11.
      That solves the riddle: I removed the original NGKs.
    • By PeterF
      I've got a problem with the idle on my 96 LS400, 145k miles. The car is up to date on its servicing and there are no warning lights on. The car starts fine, hot or cold, and drives normally without complaint under any driving conditions, except when the problem occurs. After a run of about an hour or more at motorway speeds, when the car is coming off the m-way and slowing down at the end of the slip road, engine revs will occaisonally drop so low that the engine cuts out. It will re-start from neutral without any problem and will not repeat this until it's on another long run. So, it won't cut out again when I stop at the next junction or set of lights. It only seems to be a problem slowing down after the m-way run. On a regualr trip I do, I've tried running with the cruise control off (normally it's on on m-ways) but this makes no difference, the problem remains.
      I don't know if this is simply a problem with the idle speed adjustment - it ticks over at at about 400 RPM which I think is a little low - or somethink linked to idel air control or temp sensors.
      Any pointers would be welcome.
    • By Matt1986
      Hi all. My new LS400 has no working radio. When I bought the car the aerial didn't operate so I put it down to this.
      Upon investigation this afternoon it seems the aerial was disconnected for some reason as once I plugged the connecter back in and switched on the stereo it popped out smoothly and fully.
      However I now only get static on all frequency's. It's finding nothing. Any ideas on the issue or possible fix?
      Thanks again everyone for your help!
      Matt :-)
