Ls400 96 Alarm
Nigel Allum
My Alarm has started to go off.Mostly night time,Noticed when there is distinct temp drop.Cant be arsed with it.How do I disconnect  the alarm? I have found one horn and and disconnected that one [drivers side wing area] But where is the other one located? and by disconnecting will I cause any problems.Helppppppppp.
Hello and welcome to the LOC
On earlier models the problem could be caused by the door light switches but unsure if the later models have physical switches or not.
I also vaguely remember something about metallic items like loose change in the centre console causing problems.
Also check the bonnet lock switch attached to the latch mechanism.
Finally from me anyway, have you tried locking the car with the key instead of remotely?
