It's snowy out there - about 6-8 inches in places.
Even in my ( wife's ) RX with winter tyres, it was somewhat stressful.
But we got 'there' and we got back again.
:xmas:
1 minute ago, stevet said:
Not a drop in Stockport
Gosh!
lots of snow here in Holland. and as usual the country comes to a standstill, trains get canceled, traffic moves with 15mph, traffic jam galore. How do they do that in Switzerland?
My first time driving a gen2 RX in the snow.  Anyone else nearly bin theirs into a hedge too?
Image result for snow driving gif
I've just come back from collecting my son from hospital in 6-8 inches of snow.
no issues and was very enjoyable in fact with winter tyres fitted.
it was great moving around abandoned cars on the road.
I felt safe and being a responsible driver getting my family home
I thought it was only the UK that came to a standstill with a millimetre of snow!
... and I used that 'ECT Snow' button things. it did seem to help.
1 minute ago, grantwils said:
What tyres are you using PCM?
On my wife's car, they are Khumo Winters...
( On mine, Michelin HP Tours, which are Mud and Snow, but NOT winter as such. Sometimes described as all-season  ... more due to their tread pattern than composition, I suspect?
Got barely anything.
Although I discovered that the 4RX no longer has the Snow Mode. ECO seems to do the job in the same fashion though
Nothing in south Hampshire... :sad:
I used to press that on my IS200 and it didn't work: It didn't make it snow. :xmas:
I was wondering what the rx400h is like in the snow. I agreed to buy a 2006 model (is that a gen2) last weekend and hope to collect it next weekend, but by then the snow will have gone.
From what others have said, there is a snow setting?
I've driven mine in the snow a few years back fairly deep and found it superb with plenty of grip and stability, standard tyres aswell, maybe the extra weight of the hybrid batteries helped.
I know that they have 4WD capability so that the hybrid system can deliver traction as part of normal driving.  I wonder if the 4wd system activates when wheelspin is detected as well.
I'm in a 350 Peter, with old mismatched tyres on it the sensation was predominantly RWD.  Very interesting in a big heavy jeep with no traction.  I made it to work and immediately had a new set of tyres fitted (Hankook Durapro) which has given me the confidence that the gentlemen above have enjoyed.  Totally put any scares I had down to the old tyres and my lack of driving ability.
Snow mode seems to adjust the throttle response and gear shift in relation to RPM.  When pressed it gives a reassuring feel of additional traction and stability, I believe that most Toyota models have this feature built into their electronic transmission control.  Even my automatic Starlet has it.
Hope that helps.
Yes the 4wd system (that is the 2 rears activate) cuts in and out as required when wheelspin is detected.
The rx300 is a permanent 4 wheel drive system I believe. I was very impressed with my first winter in the Rx, mine has been fab in the snow the last week had no issues and haven’t got stuck yet. Bridgestone normal tyres on mine
What is the 3RX RX450H 2012 onwards facelift model like in snow (and ice for that matter)?
FWIW the CT200h on Michelin Cross Climates was a good combination today. In eco mode the throttle is smooth enough to avoid any wheelspin on ice/snow except when I got home and had to turn the traction control off as the computer said no to ascending the final incline of my drive.
Fine in snow. Any car in ice is going to be problematic.
with winter tyres fitted you can drive perfectly in any snow, and you even get used to it if it stays there for a week or so. The super careful driving of the first day is replaced by some confidence.
Ice is a different matter altogether, best to abandon the car and go to the pub..
It is odd people still ask about how a certain car is in snow. It's either terrible or brilliant depending on what sort of tyres are fitted.
Yes, quite right. Will change to Michelin Cross Climate when due.
  • Similar Content
    • By colin79666
      Yesterday was good weather wise for car washing (i.e. above freezing) so I thought I'd share my cleaning routine that I follow every 2 or 3 weeks depending on weather. I do about 250 miles a week so this is a clean every 500-750 miles across mixed roads in southern Scotland.
      The aim of this isn't a super detail but something to keep the worst of the grim and road salt at bay and that can be completed in under an hour when the outside temperature isn't conducive to spending too long on the job! I prefer to do it with my own equipment as the stuff at the supermarket jet wash is rather harsh and can strip wax.
      A couple of pictures first to show the built up of winter grime.
      First up a good layer of snow foam to drag off the worst without risking scratching.
      After giving it 5 minutes to dwell and a light rinse with the pressure washer (nothing too fierce at this stage) about 90% of the dirt has been removed.
      Next up are the wheels. I give each a spray of cleaner, give it a couple of minutes and then wash off at about 80% pressure.
      Next up with the main wash. Speed is of the essence so I go with spraying on the wash/wax solution. I then wipe this over using 2 buckets and 2 wash mitts (one for the top and the other the lower parts).
      Finally the suds are rinsed off at 80% pressure and the windows cleaned. Results:
      Products used:
      Pressure washer - Karcher K4 Bog standard buckets, one with a Grit Guard Wash Mitts - Meguiar's Lambs Wool Foam lance - Elite Car Care Foam - Bilt Hamber Auto Foam Wheels - Bilt Hamber Auto Wheel Cleaner Wash - Autoglym Pressure Wash Windscreen - Autoglym Fast Glass Other windows and mirrors - Rain X 2 in 1 I do a good clean in autumn including wax with Armour All Shield that lasts well into winter so the dirt doesn't stick too bad. Inside I apply Gtechniq I1 to rain/snow coming in doesn't soak the seats or carpet. Come late spring the clay bar will come out to remove the ingrained stuff like tar sports that have accumulated over winter and I'll spend a full day pouring over it.
    • By Ten Ninety
      I am posting this for the information of other GS300h owners who are considering changing their tyres. Please learn from my own stupidity. Do not purchase Goodyear Eagle F1 Asymmetric 2 in size 235/45!
      When looking at reviews, I found near-universal praise for these tyres (in other sizes) for being quiet, comfortable and low rolling resistance. Despite the fact that I know full well that tyre reviews are second only to food reviews for being utterly pointless subjective tripe, I allowed myself to be persuaded away from spending the extra on Michelin CrossClimates which have been recommended by owners on here. That was foolish, and it is going to prove to be an expensive mistake.
      These tyres are not quiet. They produce noticeably more cabin noise than the OEM Bridgestone ER33s, which I did not consider to be a quiet tyre in the first place. They are perhaps more 'comfortable' in that they make the car feel as if it's driving through treacle. However, the biggest problem is that the rolling resistance is absolutely, utterly, appallingly terrible. Unbelievably, it has actually made a noticeable impact on performance - significantly more throttle is now required in any given situation, and the distance I can get in milkfloat mode has been considerably reduced. As a result, fuel economy is now catastrophically bad. I'm not talking a slight reduction - I'm talking a minimum 10% worse and on some journeys up to 20%. Where I would have been touching an indicated 50mpg on these cold days, I am now struggling into the low 40s and occasionally dipping down into the 30s. If I needed more proof that those ridiculous EU economy ratings are anything other than fabricated bulls--t then this is it - these tyres have the same rating as the ER33s they replaced, and the associated mumbo jumbo claims a maximum difference of 7.5% between A and G!
      I hoped they might just need scrubbing in, but there's been no improvement after a few hundred miles. I have tried whacking the pressures up to 2.7bar, but this has had little impact on economy. It just makes the ride unsettled. And yes, I've checked they were fitted the right way around!
      Clearly, these tyres can't be universally awful. I've actually got the Asymmetric 3s (the updated version) on my wife's Auris HSD and they're absolutely fine. However, on a GS300h they are an unmitigated disaster if you have even a passing interest in fuel economy. I hope this information may save others from making the same mistake as I have made.
    • By PCM
      Has anyone here recently fitted all-season tyres to their RX?
      My wife's RX350 needs new tyres, and all season might be the way to go?
    • By PCM
      Starting to think about Winter, on the year's hottest September day.
      Just cleaned out my and my wife's Pollen Filters. They were dirty!
      Tyres fine. Antifreeze fine. Battery new. Hi Viz in the boot. Anything else?
