carnut1980
GS450H Leaky rear section exhaust, at the 'split'
The rear section of my exhaust has a blow,at the 'split' where the two rear pipes separate,  i can pretty much see it, but neither the Holts gun gum, nor the Granville paste, seem to be able to stick for long enough. A few hours drive, and the dried paste has managed to push out and away.
I don't really want to spend £600 on a new rear section, surely there must be a simpler way to repair it? Even if it involves a 'bodge'?
cheers all
See if you can get someone to weld it up for you.
Lexus even offered to do it.
  • Similar Content
    • By Davearia
      My middle and back section of exhaust need replacing and I'm struggling to find anywhere other the Toyota to buy one from. I live in the north west of England does anyone have any suggestions of anywhere to buy these parts from please?
      Thanks,
      Dave.
    • By ultimatequinoxe
      So to my amazement my late 2000 (T3?) GS300 passed the MOT with its very aged and knackered exhaust. Two advisories, webbing of a seat belt and "oil leak pinion rear diff". So two questions if I may for your thoughts, experience and knowledge :)
      1. Theres no Diff whine, and though wet, I'm not getting any drips. And to be honest I've not had a leaky diff on any car before. Is this common? Tough to fix? Indicative of anything major (other than the diff running dry of course)? (cars just coming up to 150k miles)
      2. Exhausts. How much difference to the sound do the "resonators" and maybe third cat make internally? I don't want to lose back pressure anyway, but I see/read that people who have fitted stainless steel systems without the "resonators" on the middle/Y-pipe are getting a lot of drone inside. What needs to stay in some fashion to keep the internal noise level as close to stock as possible?
      I ask because I still want to replace the system from the front to the back (not the manifold and 2 front cats though, they're okay). Standard systems used are £300+, third party new totals around £400 or so. Stainless steeel fitted new, cheapest quote so far is £390 (I've had loads of quotes). However, thats almost certainly without the resonators/mufflers on the Y pipe.
      Last option and most likely one is some shiney tail pipes from the USA (those plus shipping works out cheaper than UK fitted ones). All I want is a healthy system in the middle (third cat/front pipe and middle Y-piece) and shiney non-OTT tail pipes that just give a little more external tune for the lovely 2JZ. Seeing as standard rear boxes are pushing on £200 a piece new, I can get a pair of stainless steel ones for about £280, or for £340'ish I can get a Manzo cat back (Y-piece and rear boxes) however the Y-piece has no "resonators" and tempting as it looks, I fear a terrible noise inside and possibly a drop in back pressure I'd rather not have.
      Sorry for the waffle, but the whole picture might save some guess work for you :)
      (Images of a standard system and a Manzo cat back for reference about what I am waffling on about)
    • By Blucky
      I have a 1999 Toyota Altezza 1GFE, which recently has had the engine light come on after driving it for a few minutes. Every time i restart the car it goes away but comes on again after a few minutes.
      I have done the paperclip diagnosis on the ODB1 port, but all it does is make the engine light, ABS light and the ECT light flash continuously.
      Does anyone know what it might be?
      Cheers,
      Hi all!
       Having had my latest GS300 for a couple of months now, the MOT is due and I know the current exhaust is an issue (see pics).
      I have been desperately hunting for a stainless steel system in preference to an OEM seeing that the two used ones on eBay are a mighty £350! And MIJ have quoted me £445 for new S/S with life time warranty (as an FYI).
      So the questions are:
      1. If I plug that hole in the back box, and make sure that and the awful paste all over the joint isn't leaking either (thats how I bought the car, not my handy work I'll add) might I stand a chance I wonder, as technically the fail is excessive corrosion. But I fear all that putty is an obvious giveaway of excessive corrosion even if its not leaking.
      2. Another MOT requirement seems to be the correct number of baffles/mufflers, so should one slap a S/S cat back on would it be an issue. Or should I maybe say has anyone taken there car (any car) in for an MOT with a S/S cat back and had any issues other than possible noise or emissions?
      Many thanks! I am getting a little frustrated that in the last two months I've not found a single second hand S/S system and I'm not really wanting to throw to much on the car just yet until I've had it a while longer.
    • By Si_is200
      Is200 Japspeed backbox stainless steel includes adjustable baffle, used so obviously has cosmetic marking but overall in really good condition, polishes up great. Can send pictures of it fitted at request.
      £99 Ono
      collection from Durham DH9 or willing to meet within reasonable distance
