Sign in to follow this
Laim1987
Wheel spacers
HI im new here. I looking to put 10mm wheel spacers n maybe some one knows do i need new bolts or something else? Or it's fits on original bolts? Thnx
eibach spacers are excellent, just ensure you buy from a reputable supplier as there are fakes available, obviously ensure if your just using a spacer that there are enough threads to use
  • Similar Content
    • By sannyp
      Hello,
      So I recently got into a little accident with my is200 manual and now need a new rear hub, and maybe other parts although unsure what yet. Question is will parts from a is200 auto suffice. So I wanted this post to outline the differences.
      I know the differential is different with a higher ratio i believe, and obviously the tranny. But is there anything else?
      I have a guy ready to sell me a bunch of parts from an auto is200, but I'm sceptical with mine being a manual
      thanks
    • By pawlopc
      Hi ,
      I have some problem with my 1999 IS200. When I try to open doors using key, only driver door opens. Power door locking doesn't work. When I try to close doors using indoor switch, it doesn't work as well.  Same goes for locking it with the key fob. Only lights blinks but doors don't open or close. Opening boot with key fob works correctly.
      Has anyone any ideas ?
    • By Liso
      Hi.. I have a 2002 Lexus IS200 Auto, I am having a transmission problem. At first I thought it was caused by my ABS sensor, my ABS light on and TRC OFF  flicking, which when diagnosed it was front right side. After replacing that sensor the transmission was working fine for two days but started doing its thing again. The car will just refuse to change from 1or 2 untill it redlines, if it does change to another gear it will be just for a second or so and back down. Some days it will drive smooth for two hours or so and if you going slow there is a slight jerk as if the car is changing up and down.
    • By Blucky
      I have a 1999 Toyota Altezza 1GFE, which recently has had the engine light come on after driving it for a few minutes. Every time i restart the car it goes away but comes on again after a few minutes.
      I have done the paperclip diagnosis on the ODB1 port, but all it does is make the engine light, ABS light and the ECT light flash continuously.
      Does anyone know what it might be?
      Cheers,
    • By mondo35
      Hi guys, i have owened 3 lexus is 200s
      and I absolutely love them,
      just recently i thought about having a caravan so i sold the sport and got the is 200 SE
      I have the tow bar and everything, i want to know how much the standard is 200 weighs.
      as my car and caravan must be 3.5 tonne or under. Now can anybody please tell me how to find this out, i have looked online allready but have had no luck
      thanks in advance for all the replys,
      much appreciated
