Looking for lexus service garage
I have just found out that my usual service place in Swindon 'Gas & Go', is no longer servicing cars, a great shame as I found them to be pretty good over last 5 years.
Does anyone know of a decent place in the Bristol, Cheltenham, Swindon triangle that they would recommend for working on the LS.
Thanks for info, I forgot to say that my beast is not LPG, but Osaka look like a possibility, at least I can get train back home if I needed to.
Cam belt due next year, so want an independent who understands Toyota/Lexus
Why would it need a toyota/lexus specialist? any competant indi should be able to do it, also I suggest you use a cambelt 'kit' & get the water pump & tensioners etc changed at the same time
My own expereince of good indi garages is they are great for 99% of things, and in the main even cambelt changes etc, but always like to have a indi that does specialise in a particualr make of car for those 1% of problems that the specialists are more likely to have fixed in the past.
Had running gear issues on my Omega years ago, the indi tried this, and tried that, and after a little too much expense a local Vauxhall expert got it sorted, and funnlily enough had simialr experience with suspension issues on my Mk3 LS, which at least my Indi chap admitted he did not know what the problem was.
So I will probably keep Osaka (and Japex) in my telephone just in case I have another one of thos 1% problems.
Got the same issue with my wife X-type, with very random fuel problems, so hopefully located an indi Jag specialist who can have a look at.  Trouble is they are all clocking off for Xmas about now
The only indi I am aware of which had an excellent reputation on this forum and until recently (this year sometime) advertised as a Toyota & Lexus specialist is grove garage Brighton, I now notice their web site has changed a lot, but here it is:
http://grovegarage.co.uk
True, there's not much they don't know about Lexus.
They have nice new premises as they were just to busy to carry on in half a dozen mews type garage. Still the same good service.
