Hi
Does anyone know what the light bulb fitment is for a 2013 lexus rx450h?
in addition, can anyone recommend a LED bulb to replace the lexus factory hid bulb?
thanks.
alex
6 hours ago, roc888 said:
Hi
in addition, can anyone recommend a led bulb to replace the lexus factory hid bulb?
thanks.
alex
Replacing the factory HID bulb with an LED is illegal and will fail MOT
I believe the bulb is a D4S. Change both at the same time especially as there may be a colour difference.
If you want an LED look go for colour of 5000k
23 hours ago, roc888 said:
what is the current colour on the factory hid bulb?
any recommended brands of aftermarket bulbs with 5000k colour?
thanks.
They were probably 4300k semi yellow ones.
I would go osram nightbreaker or philips.
They won't be bright white but they will be whiter than normal ones.
You can also get osram cool blue intense which is LED like
i find the hid lights much yellower and less bright than my previous is250 sport.
Are the rx hid light bulbs easy to change or are they like the is250s which can only be carried out by a mechanic?
I'd probably let a mechanic do it as you'd be messing with high voltages. Shouldn't take longer than alf hour though
ok noted.
Does anyone have comparison pics of their rxs with these LED looking bulbs vs the factory hids?
7 hours ago, roc888 said:
ok noted.
Does anyone have comparison pics of their rxs with these led looking bulbs vs the factory hids?
You probably won't find any
But there are plenty of pics on the net
79825-hi-power-xeno-lamps-replace-origin
You need Osram Nightbreaker unlimited xenarc in d4s with 4800k temp
Those bulbs look very bright and good. Will installing these bulbs void the lexus warranty?
