Hi all, can the "moon roof " be adjusted manually as when I try to open mine it seems to try to move back before it drops down to then slide back and makes a loud band as it is pushing against the rear of the opening?  This seems to have happened  after I tried to open it while driving and my mate also at the same time pressed the tilt button. I've tried doing a reset by pressing the up button and letting it go through its sequence but hasn't made any difference it also won't do a auto one press open/close thing it's that bad that I'm  concerned that it might shatter or bend the car roof. My car is a 2005 GS430 Thanks for your replies in advance Brian.
