iffy
Lower ball joint advice
My front lower ball joint is very worn. Can users please share their experience in changing this part out? Also what brand should I look to replace with? And where should I buy from. Thanks
I had someone who knew what they were doing change them for me. I watched the whole duration, it's a case of having the correct tools, and remembering where everything goes etc.
I would use Toyota ball joints from the dealer, or Moog if you can find them. Other than that I wouldn't bother as the cheap ones wont last too long at all based on many iS200's i've seen with a wheel through the wing because of them.
Take it trw at 40 quid a side is no good
I wouldn't risk it myself. Not for the sake of £20 extra a side.
True. OK then lexus it is. Hopefully Barry gadgy will give me a 10 percent discount. But I like dojng my own work and will buy any tool required, in that case is it advisable to do it or not?
If you feel confident enough then go for it. Will need tracking after though.
