Hiya mate
Thanks your all over the place this must be the 3rd time you have helped me out thanks...
I dont have a manual for the sat nav but ill get a look i was looking in the boot but never thought to look under the floor mat...
With thanks
If you find the unit you need to ignition on to eject the disc. Should be a button or a level you slide across and the disc will eject. If it's like the GS one then the sat nav unit is held down by two clips. Undo these clips and the whole unit can be tilted up to provide room for the disc to come out.
