Added Sat Nav To My Is200se
idmax
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
Guys in the US have fitted Farenheit 7" screens in, and I am planning on putting my Lilliput &" touchscreen in one. The Xenarc should fit too. On digitalww.com it explans how to rmove the xenarc & lilliput from their supplied housing so that the screen & electronics can be moved to a custom built housing:) Will give it the complete stock look!
I wold imagine your 6.5" screen would fit no problem...
But to get those screens in dont you have to take them apart and remove there body? I dont really fancy having a go with the Alpine just incase I wreck it. If I knew it would go in then I would defo be in for one of these!
That install looks really good, almost like the original. Just curious to know how good the traffic updates are. Does it just warn you, or provide good re-routes? Also, does it only work on motorways and large A-roads, or does it have more coverage than that?
Right!
Been terribly busy all the time with the renovation of my living quarters etc..
But here goes...
The TME-M770 CAN be adapted to fit into the oem LEXUS sat nav monitor console.
The Motorised console I was developing is at a stage where it is fully working.
A console will be going out shortly for review and evalution to one lucky LOC member, (you know who you are), As for the sat NAV package to go with my SOLUTION, you can use ANY sat nav computer thats on sale, including the all new ultra quick access NVE-N099P Alpine DVD sat nav unit. However you will NOT be able to benefit from the touch screen feature.
However, just to keep the cost down, people can go for the older version Alpine DVD sat nav with my motorised monitor solution shortly.
OR at a later date go for the TME-M770 touch screen with NVE-N099P but this will be at a rather high price with the top dash motorised solution.
Hope this helps.
Its far more expensive to do it this way, as the parts for the OEM nav monitor housing are expensive, region of £500 for all the bits plus your monitor.
My solution bits will be cheaper plus your monitor, much cheaper.
SteveAudioX, Will the TME M770 screen fit into your motorized console? If it could I would be very interested in buying one of you, at the moment my screen is on display all the time and i dont feel to good leaving it in car parks. Thanks.
The cable should have been supplied, you need to contact the shop where you purchased it from and ask them to supply you one.
Thanks for replying.
Just got it from their shop :)
I don't know if u still remember what else are in the box?
I got:
-Monitor
-AV interface unit
-Power lead
-Monitor stand
-Velcro with 4 screws
-L plate for monitor
-Instruction manual
-Connection cable(got it now)
Cheers :zee:
