1. Which fuse/relay corresponds to opening the boot. I have found 3 fuse boxed and all the fuses are mark with acronyms and only *** know what they stand for. When I press the key button to open the boot I can hear a click but it does not open. I have release the lock under the steering wheel and get the same problem.
I cannot open it using the key or the switch inside the car, only by the key in the lock.
2. I don't know if it me but does the stereo in the GS lack bass. It is very loud but it seem to be all mid-range and tops.
3. What product do you recommend to get that showroom shine
4. I have just put on new brake pads on on the GS300 with Sat Nav 1999 model because the old on was sqeaking and I have the same problem . The old pad looked fine but I don't like any noise while driving. I have check the disc and it is fine.
5. How do you get you picture on the side of you post ?
I have check the fuses in front of the Battery and non correspond to what you say "body ecu 1" The fuse for radio no 2 I took out the sat nav screen went blank. If this helps I can here a clicking under the passenger leg room when I try to open the boot.
Gonna check Every fuse as well in the mean time.
