Air Con
Adie
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Finally changed the air con filter to a new pollen one. Its been sitting in the kitchen for ages :blush:
Had a quick read of Mat's knowledge base guide and the job took about 2mins :D
Problem has now gone :D
Thanks to Chris S for supplying :winky:
I replaced the pollen filter which was filthy by the way absolutely disgusting  :crying:
Solved the problem in one...
Me too pal :rolleyes:
just a thought about the kettle idea, one flaw with the whole thing, the bacteria that creates the smell requires quite high temps to be killed off.
steam is about 100C, and as soon as it leaves the water surface/kettle it is cooling down quite quickly so by the time it has reached the evaporator its going to be quite cool - impossible for it to kill the bacteria.
What i suspect is happening is collecting on the filter, soaking that a bit and then stopping whatever thats making the smell from going into the airstream.
to properly clean the aircon on the IS you need an aircon spray that u place in the footwell - dont bother with the ones that have a long tube attached - u wont get it anywhere the evaporator.
