annoying noise behind radio and air con
Actually Loz, the fan is behind the glove box - so it prolly isn't that.
Most likely to be a loose captive screw.
You can pop out the top vent (the one with the clock in) by prising it out carefully with a small screwdriver or knife.
You can also pull out the ashtray assembly - it just comes out with a good pull.
On my car, the radio/satnav unit then comes out with four 10mm bolts - can't be too different on a non-satnav car.
  • 1 month later...
