Power Steering Pulley
bowker
The pulley looks off pulled forward at the bottom and it squeels when you turn the wheels
Not sure if this could have happened during the accident
Would the whole unit need replacing or just the pulley wheel?
If the pulley is a bit ***** eyed then it is likely it has bent the shaft that goes into the pump and knackered the bearings and seals etc. It is possible though to buy all the internals seperately but you would need to strip the pump down to see what has been damaged.
The pump itself is nearly £500, but the internals are actually quite cheap (the shaft for instance is only a tenner!).
never knew ***** was such an offensive word :shutit:
