Brake Discs
lexlex2
Wanted to know because my Pads will need changing soon. But Discs are usually damaged by worn pads. There is no sound of any damage or wear and tear although still very smooth there are however visible circular markings on the shiny steel outer surface of the discs. So I was a little concerned. Just the front ones.
If theres a big lip around the outside edge of the discs then the discs are showing signs of wear,but by the sounds of it there fine,the circular marks on the discs is because like you say the pads are low,the pads are heating up quicker and holding more heat and transferring the heat to the discs.You may also find the brake pedal is getting softer if you brake hard.
Cheers chips.
Another thing, whats the best place to get set of pads and front discs; from lexus or some place else. Clearly I am having a brake attack but cant afford to compromise on brakes for much longer. All those useless trips should have stayed at home to conserve fuel also. (Ha!)
Thanks, So are you saying ideally the pads should be changed now rather than the marks getting worse
If your doing alot of driving and at motorway speeds id change them now,if your just driving the car local,to the shops etc they will be ok for a while.
Yes good advice. Thanks.
Prices from lexus are as follows.
Front Pads (set) £58.24 +vat (part number 04465-30320)
Rear Pads (set) £34.44 +vat (part number 04466-30190)
Front Discs (each) £74.22 +vat
Cheaper non lexus parts are also available but I have been advised not to go for anything too budget as they could ware out much quicker.
The part numbers if specified at a Toyata garage may also be available there. Hope this helps people with brake change ideas.
Get the disc thickness measured. Minimum is 30mm, they are 32mm new. If they are 30.5 or less I would change them otherwise they would need changing before the pads need doing again.
You could also get the runout checked. That should be less than 0.05mm
I Had the Discs measured. Both front are less then the minimum. Readings were 28mm +/-. Although the braking is still fine and it was time to renew the pads clearly its both Pad & Disc change time now sooner than later; maybe someone would like to add now urgent.
If they are below the minimum. you are putting your own and other people's lives at risk - get them changed tomorrow!
Yes ASAP. Firstly I found out very late but just glad that all is OK and all was OK. I am simply astonished and impressed that the braking is still very good but after the change it is likely to feel very different also. So I will find out how soft and spongy it may really have become.
Can people confirm that the front discs for 1998 Mk2 GS300SE are the following spec and in particular do they also have the 5 extra vented mountings on the original lexus discs. Cant seem to remember now when wheels were off last time.
Thinking of ordering these. If anyone knows any others grateful for info.
http://www.speedways.co.uk/shop/en-gb/dsk316.htm
Thank you Mr. Morse.
But my local autos Garage Jap Specialist is offering ADL Discs and Pads.
I can only take satisfaction in the fact that after running with worn discs and nearly worn out pads that I get both items changed for future use.
Although I am not an expert to know if such poor condition & usage affects other brake components. Hopefully not.
The ADL deal on the Discs is £117.40 + vat (pair) a considerable saving on the Discs from Lexus. Any ADL people out there please let me know.
