Is 200 Engine Oil And Power Steering Fluid
daverz
engine oil - use a decent multigrade. if you change your oil often, then it's ok to use a mineral, if you go long between changes, like the service schedule suggests - 10k, then use a good synthetic, like mobil1. capacity for a manual it's 4.0l without filter, and 4.2l with filter. for an auto it's 3.9 without, and 4.1 with filter. 20-50 will cover temps from -7c to 38c, 15-40 = -12c to 38c, and 5-40 will cover -18c to 38c.......
the power steering uses ATF dexron II or III
