How To Stop Is200?
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
hi,
how do you stop an is200 engine starting without damaging anything and with fuel in the car?
cheers,
Not quite sure what you mean? Do you want the engine to turn over but not run?
- Remove the plugs
i mean when driver starts engine it wont start.
I think he wants to park it somewhere, and prevent it from being started without doing permanent damage.
Some kind of DIY immobilizer - like in the old days you could pop off the distributor cap and take the rotor arm with you. Maybe he can pull out a fuse (fuel pump, starter)?
He does not want the car to be able to start even if someone has got his key. The best way to do this is unscrew the two wires from the Battery terminal and then use a deadlock to lock the terminals of the two wires together.
Take out the starter relay
This is only for temporary relief but it won't take them long to sort it out and put one back in or short the circuit.
I've got my old car stolen even with the relay and Battery removed from the car.
If you need to give someone access to the car with the key but don't want them to drive it then simply take the immobiliser chip out of the key before you give it to them.
Just unscrew the small screw in the key itself and remove the chip inside. The car won't start without the chip!!
is there any other way?
take the wheels off
:lol::lol::lol::lol::lol: I LOVE IT
This HAS to be the MOST infantile thread on this forum.
Methinks it started as a genuine question which degenerated into paste
WTF are you on about pal? :blink:
I've seen worse :duh:
I've have as well, and had a good laugh at those too :winky:
and your mature suggestion is................................... :question:
Victor :lol::lol::lol:
Sorry guys, these couple of posts just creased me up.......
