refurbishment of the supercharger
Rob
Top stuff mate. Reckon mine could do with a clean up....think my clutch is in need fist mind....well, thats if the nail in my tyre I found earlier hasnt caused it to go flat...
Did it cost you much to do Rob?
  • 1 year later...
Apart from my own time @£35 PH - who knows :yawn:
bearings( if you can find all of them!) and new supercharger oil about £ 35
Front oil seal £.0.80
stainless allen key bolts + washers £10
painting = free
machining work on pulley = free
sealants, retaining fluids, threadlock etc = free (from work) :whistling: but otherwise loctite 510 £28, loctite 638 £30, loctite 242 £40 for 50ml tubes, but 10ml tubes are available
pulley drive bolts about £90 but they were free :whistling:
the 5 weeks finding all the info and tracing a bearing = priceless!
Just had a read through the thread and glad someone has done this before! I was driving today and all of a sudden heard a bad noise, lost power and smelt burning rubber in the engine bay! My supercharger has decided to cease!! :(
Until i open it all up to have a look whats wrong (hoping just the bearings or sumthing not too expensive) can the replacement parts be purchased direct from eaton or Rob can you remember where you got yours from??
Also might be a silly question.....is there a hole or filling spout to put the oil in?? or do you put it in before you put the snout back on??
Tom.
  • 1 year later...
