Boot Lid Gas Strusts
The springs on my IS200 Sport boot lid are too weak and it only opens about half an inch when the locking mechanism releases.
Some ever-so-helpful members have directed me to this thread
Boot Lid Needs Viagra
detailing where to find gas struts to use instead and how to fit them. Looks a fairly simple job, even for the likes of myself!
The thing is, you only need one strut but have to buy in pairs so if I ordered two, one of them would just go to waste.
Anyone interested in going halves on them?
Here are the parts :
Gas Struts
They're £41.19 + about £5 postage so if anyone wants to go 50 / 50 on the total cost including P&P, I'd be happy to forward one strut to you for free (UK mainland!).
Thanks, Steve.
Would it damage the bootlid if it came open too fast?
Probably but as it says in the descriptive thread, you can adjust the pressure and rate at which the rods extend so on the first few attempts, you'd just have to keep hold of the lid to make sure it doesn't snap open. Once you've released the right amount of gas then it's not going to damage the boot lid and you can always add rubber grommets to control the 'bounce' that some people have mentioned. If I thought there was any chance of damaging my car then I wouldn't do it.
As for any 'butchering' (lol), there is already a hole in the arm that supports the boot lid so the only thing you need to do is attach the bracket to the back of the seats which just requires a couple of self tapping screws. If you decided you didn't like the strut and took it out, nobody would ever know it had been there.
With regard to ordering from RS, I didn't read through it fully but it sounded like you only got free postage if you were a member but I haven't checked what's involved with that.
Tell you what, I'll order the parts anyway and have a look for TWO brackets, then I'll get back to you all and see who wants one :winky:
  • 8 years later...
I just got an IS200 and the torsion bars in the boot are foobar.
Just been to the breakers and found some 440mm ones but I think the bolts are not long enough to go through the hinge.
Does anyone know what cars have boot struts that are suitable for the IS200?
The ones I got came from a Citeron Berlingo. I think they might be too strong also.
Thanks.
11 minutes ago, andy_in_leeds said:
I've done this job now so I have a spare strut if anyone wants it.
You're actually supposed to replace them in pairs, even if just one has failed, because the new one is obviously stronger than the old one. Force variation will cause side loading and premature failure.
