water spray
superchargedmorph
the water spray would make the cooler more effective, hence a denser air mass flow, which would then be picked up by the flow sensor and the mixture adjusted in relation to the mass.
not convinced about the power increase, sorry!
robbie.
Instead of using water spray like Impreza's, why not use a chargecooler which is basically a water-cooled intercooler. This should increase the charge density more and give you some more power. Although noone might make one i'm sure it would be not to difficult to adapt one from another vehicle. Plenty are made for Ford Cosworths and Impreza's.
  • 1 month later...
