Removing Headlining From Is200
can anyone point me in the right direction on how you would go about removing the head lining from inside an IS200
any help welcomed
really easy
unscrew all sunvisors,rear view mirror,center light(lift out light cover and theres 2/3 screws),grab handles.
unclip c,b,a pillar covers(easier if door seals are pulled off slightly)
and basiclly just falls out,its easier to remove if either the passenger or drivers seat is removed
not to sure about the sunroof cover yet as im yet to do it
hope this helps
azz
you got to take the bumber off i iknow this much
its a pig to do
huh???
why would u have to take the bumper off to remove the head liner??
you would if your was taking the head lamps out..... :whistling:
so yeah you don't need to take the bumber off :tomato:
i got heat stroke
its a pig to do
huh???
i got heat stroke
even for that u don't need to take the bumper off IIRC. just the arch liner to undo one bolt.....
get back into the shade matey.... :P :lol:
any help welcomed
really easy
hope this helps
azz
Thanks very much
all sorted now :D
