Fellow Lexus Owners,
The MAIN light on the roof (front) appears to be burned out and I am wondering if the procedure for replacing it is feasable without driving down to the dealer. If so, could you post instructions including the TYPE of bulb to replace it with? Thanks so much.
Chris Engelking (Saratoga, California)
1993 Lexus LS400
The same happened to me, checked fuse it was OK. Get a small flat screwdriver, there is a small indent on glass at the back. You have to be carefull the plastic tabs are brittle. My bulb was not blown but after I checked the circuit & put the bulb back in it has worked ever since.
Alan
Hi there.. i to had the same problem on my gs... yes with the screwdriver carefully.. but my bulb looked fine no broken element but the silve cap on the end had disconected even though it looked on.. i replaced it and all was well.. 5 min job. :D
jac
