Replacing Brake Pads And Discs
bakili
Thanks guys,
I was so lazy, so took it down to local garage, and let them to pull my pans down. It cost me £200, parts and labour cost for front discs and pads. While my car was on ramp, they showed me that left shocker is leaking as well. Quote me £140 fitted, so next job shocker.
It wasn't Kwik-fit was it ? I would be inclined to get a second opinion on the shock absorber and/or to clean it up yourself and see if it really is leaking (or they just sprayed some oil on it to make it look like that).
I took it to Motorsave Doncaster
Yes you are right, i will give it good clean, and see.
About brakes, they are so much better now, vibration stopped, noise gone.
MotorSave Say No More :whistling:
Why? Are they so bad?
Id 4got about this my other half reminded me we took our Vectra :blush: there & they did the exact same so probably toutin 4 work Screwdriver job he went nuts & was gunin 4 1 of the guys behind the counter cos it had just passed its MOT so would have failed had that been like they said so just watch em :tsktsk:
I knew there was a reason im not keen on them lol
