After Fitting The Blueflame
Asi
same trouble on a is300, they have more lambda sensors on them, fitted a o2 simulator to the sensor after replacing it, have a couple of sensors lying around if anyone needs them, my old ones wasnt faulty just sending incorrect signals due to exhuast change and flow charectoristics, also most exhuast garages dont have time to remove sensors properly, they leave sensor plugged in which coils the wires up, which have become brittle due to heat exposer from exhuast, resulting in broken wires. sorted now though, and its not rich at idle thanks to o2 sim from prolex
hope this helps
