for this you will have to remove the front bumper. this is done by removing-
the clips holding the inner wing liners
the 2x ten mm bolts holding the top corners of the bumper
the 10mm bolts that run along the bottom of the the bumper
and the clips and 10mm bolts near the grill
the bumper should be able to be removed, becareful of wires from parking sensors (if you have them) and the pipes for you headlight washers, these should be disconnected and then you can get to what you need very easily.
Great stuff
Thanks very much for your help
Norman
