duttnut
Check Your Timing Belt Early!
2 hours ago, scudney said:
it's 60k or 6 years whichever comes first and not 10 years or 100k(it was revised downwards),there seems to be a bit of confusion on this but it was originally 100k but later revised to 60k
Fair enough, but either way he needs to get them done now :smile:
Is the downward revision to 60/6 just for the IS200 or the whole Lexus range?
I know it applies to the mk1 IS200(as I still own one) but does not apply to the IS250 (also own one) as it is chain driven.
Definitely get it done. If you get Lexus parts it will only cost about £35 for the belt and £65 for the tensioner. Because I was dubious about letting an independent do such a critical job, I got Lexus to do it. Cost £300 all in including collection and return. They checked the idler and water pump and said they were OK.
This is a post I remembered from some time ago, the belt rarely snaps but bearing wear in the idler/tensioner and waterpump can cause the belt to run untrue resulting in what you see.
Reviving an old thread again. (What can I say? It's an old car)
Would my IS300 be included in this move from 10 years/100k miles to 6 years/60k miles? I'm going to be pee'd off if it is because a) it's the first I've heard of it and b) that makes my car overdue and the interval was mentioned more than once prior to purchase from Lexus.
just a bit of advise,even if it isn't,do you have any history to say its been done?if not its better to be safe then sorry and have it done
If you do need to get it done, I would get it done by Lexus as it is such a critical component. If they mess  it up then you have far better come back than a local garage. However, shop around because not all Lexus dealers charge the same.
Yes. The car has full main dealer history and it was done in 2010. The car has still only done a little over 54k miles but there was discussion about getting it done in 2020. If the interval has changed this was never pointed out and it would be due now.
I until a few months ago owned a IS200 sports which I had for 8 years,had the cambelt done at just over 55,000 and then again at just under 80,000 miles as it was 60,000 miles or 6 years whichever comes first.However am sure someone on here will confirm  that its 100,000 miles or 10years,whichever comes first
Had a bit of garage time so I took the covers off to have a look.
Pretty healthy by the looks of it.
I also checked the service records.
Service book and sticker on the engine indicate it was done 7 years ago. The car will have been 8 years old at this point.
Schedule just says 100k miles and no mention of time intervals.
Now I'm sure 10 years/100k miles was mentioned by the dealer but this possible change discussed above does concern me. However, most posts relate to the IS200.
Can any more light be shed on this before I call the dealer tomorrow?
Did you eventually contact the dealer?if you can afford it there's no harm in having it done slightly early though
Right, breathe easy guys :rolleyes: IS300 with the 2JZ is definitely 10 years or 100,000 miles. I was advised that as long as my mileage doesn't suddenly go stratospheric I'm OK waiting until 2020.
And a nice chat with Danny at Lexus Leeds.
good at least you have now got peace of mind knowing it doesn't need doing for a couple of years 😊
He seemed genuinely enthused about the possibility of seeing an IS300 too! Yet another good experience with Lexus dealers. This is getting tiresome :biggrin:
