Have You Had An Autolights Or Other Windscreen Leak Related Issue?
loggyboy
Please no chat here, just a post if you have had an issue with a few brief details - Thanks!
Car/year: IS200 2001 Xreg
Date Windscreen replaced: July 2008
Company who replaced screen: Autoglass Bracknell
Date fault developted(First noticed): Dec 2008
List of Faults:
Lights turning on when igntion is off and lights are set to off.
Fuel, MPG, collant guages failed to work when car was running
Alarm failed to disarm leading to setting off when opening door.
Current state:
Windscreen due to be resealed.
Cost to date (not inc orginal screen/excess)[b/]
£0
Cost reclaimed and from whom (if any)[b/]
Any further relevant info:
  • 1 year later...
Date Windscreen replaced: Oct 2006
Company who replaced screen: Autoglass Basingstoke - fitted a Pilkington screen
Date fault developted(First noticed): Jan 2007
List of Faults:
Initially - Lights turning on when igntion is off and lights are set to off - Autoglass checked screen and found no issues.
2010 - Fuel, MPG, collant guages failed to work when car was running, Fuel empty light on gauge failing to work, E flasing on outside temp gauge.
Current state:
After getting back in touch with Autoglass and complaining etc with some info from LOC and Lexus Reading, I asked and got a replacement Lexus OE screen which should curfe the issues.
£0
Apparently the Pilkington screens do not seal properly around the heater cable - common issue. Lexus say they never put in a screen other that the original Lexus ones due to this issue and have never seen a failure. They also said that Autoglass head office should be aware of this issue as they have contacted them about this and to call head office to get it sorted.
