All Speakers Not Working
Asi
my head unti is 13909. went out for a drive and there music coming out the speaker a little bit but was more crackly so i know the speaker are working. so something wrong wid amp
  • 5 years later...
Hey guys. I know I'm replying to a very old thread, but my speakers went off on Friday. No warning noises to suggest anything had broken. The speakers were working before I turned the car off and they simply were not working when I got back in and started the car up again.
I've checked the fuses, radio 1 had 10amp, not broken. Radio 2 had 7.5amp, but was also not broken. Replaced with a 10amp, but this has not fixed the problem. I'm going to check the wires now, but if it is the amp, how easy is it to replace?
Stuart.
The amps are a total b!tch to get at, so to change one expect bloody knuckles and a fair amount of bad language.
If you have time i'd strip back as much as you need to get the amp out to swap, but if times not on your side see above!
