Wanted Information / Advice On Is 220 Alloy Wheels
Wayyo
Hi
I have bought a Lexus is220 D on a 09 plate that has the standard 17 inch alloy wheels. I want to upgrade them possibly 18inch however i need to know the offset of the wheels.
Can anyone help here??
OEM Standard fitting
17" RWD:
Front: 225/45/17, 17x8 +45mm O/S. dia: 633mm/width 222mm. r.p.mile 834
Rear: 245/45/17, 17x8, +45mm O/S. dia: 651mm/width 244mm. r.p.mile 811
18" RWD :
Front: 225/40/18, 18x8, +45mm O/S
Rear: 255/40/18, 18x8.5, +50mm O/S
O/S = Off Set btw :whistling:
Hi
whats the PCD???
110/114??
Hi
whats the PCD???
110/114??
PCD = 114.3mm
Hi
whats the PCD???
110/114??
PCD = 114.3mm
so will a multispoke alloy wheel with a PCD of 110/114 fit the lexus on 114.3?? thanks Tango for your help
Hi
whats the PCD???
110/114??
PCD = 114.3mm
You need the 5 studholes fixing on 114 mm pcd.
  • 1 year later...
