Lowering Springs Is200 60mm?
MSC
hi guys just picked up a is200 today and ive been looking to lower it but cant find springs lower than 40mm drop anyone know of anywhere to get say 60mm cheers in advance mark :winky:
you wont find any mate.......if you want to go that low coil overs are the only way....
Shortened struts with lowered spring is another way to get a 50-60mm drop. KYB do them in the JDM market to suit Altezza's. You can also get Koni with different rings to mount the spring seat in.
Failing that any suspension specialist should be able to modify/shorten some struts for you.
I think TEIN springs will give you the biggest drop to.
THESE ones drop 50mm and are quite cheap.
lad posted up about these the other day and said they were a very good ride and made the stance superb, is there any chance of rubbing with a car load on the standard 5 spokes or do they tuck under the arches?
  • 4 months later...
heres a pic of mine lowered about 60mm on standard 5 spokes, however its on coilovers.
no rubbing at all unless i go over a speed bump thats really bad... the wheels tuck into the arches nicely when i got passengers in the back
heres mine lowered 90mm at the front and 100mm at the rear....
no rubbing even with a full car!!
and heres what it looks like on the road..
i was sitting approx at 90 and i'd just shot past all of the cars before the bend i was on the way back from smc(large car event)and some of the peeps on the stand my car was on went home a diff way and got this pic as they stood on the overpass!!!
Since this was brought up I thought I add a bit more info.
If you are looking at lowering springs, try to stay away from anything that lowers more than 35mm.
If you are making your standard suspension lose more than 35mm of damper stroke travel, the result will be a leaking damper fairly quickly.
It also mean you can be hitting your bump stop making the ride juddery and not comfortable.
If it comes down to lowering springs brand... Eibach is the best to go for.
And if you want to go lower than that, go for a quality "dual perch" coilovers as this type of coilovers allows adjustment to ride hight without losing damper stroke travel.
  • 7 years later...
  • 2 years later...
16 minutes ago, Ronan_ said:
Anyone know if jetta lowering springs would fit an is200?
Even if they were to fit, would they be the correct spring rate for the IS200?
