Is200 Starting Problem
Made the mistake of starting and running my IS from cold for only 30 seconds or so whilst putting it in the garage the other evening. Next morning I can't start it. This has happened to me once before and I eventually got it going by persisting with cranking until it fired. This morning I have just about flattened the Battery cranking it over. So what's the technique to get it going again ?
Thanks for any advice
Simon
I would start with cleaning the spark plugs, short run may have "fouled" them.
Had the same thing with the Tezza and just replaced all the plugs anyway, still OK so far.
