Rear Trailing Bush
Dale_V
Hi chaps, the rear trailing arm bush as shown in the pic is worn on my 1996 (mk3) ls400, does anyone know where I can buy one from? I can find bushings for the mk1/2 but cant find the mk3 bushings... unless anyone in the know can tell me that the earlier bushings will fit
the bush in the hub is fine, its just the bush at the chassis end, where the metal insert has seized to the bollt and caused the rubber bush to tear
Regards
Try ACLex on here maybe !
Also check the USA owners club, look for 'bushings' USA name
Try 'Superflex' and 'Polybush'
If you are feeling brave it might be worth finding out the dimensions of the late and early bushes ;)
You never know what crosses over until you try!
Andy
From here:
http://www.lexls.com/tutorials/suspension/rcabushings.html
it shows the bushings are marked from 90-99
so found the same bushings on sale here:
http://www.ebay.co.uk/itm/5056-LS400-Rear-Trailing-Arm-Bushing-89-00-/180706385202?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a12f09d32
which indicates the mk1/2/3/4 bushing is the same, might buy these, unless anyone knows who sells similar in the uk?
From here:
Hi Dale V
This issue was covered recently by myself and another Member in the LS400 general discussion section under "strut rods and bushes" I fitted the bushings to the lower arm and the trailing arm hubside on my Mark 1 and they are perfect replacements with no hassles, unfortunatly the other member had issues because the rear suspension was changed on the Models produced after 94.
I cannot comment further on the issues as I did not have them ,but I think if you read the post and check out the workshop tip that accompanies the post it might help you to make a decision.
From here:
Hi Dale V
I cannot comment futher on the issues as I did not have them ,but I think if you read the post and check out the workshop tip that accompanies the post it might help you to make a decision.
Google ADUS 505 and look on 'club Lexus'
From here:
Hi Dale V
Thankyou very much :)
so from that rear it looks like for my mk3 I need the ASUS 583 bushing and then cut down the inner sleeve
Hi Dale,
Not checked the Owners Club for a while. I'm the other member that Ambermarine mentions. I had a go at replacing the same bushing as you with an Adus one. Was assured it was the right one but I didn;t find it so! How did you get on?
Jim
