• Save Up To 15% On Your Lexus Insurance!
    • 1000's of Lexus For Sale
    • Join Gold & Save!
      Join Gold & Save!
    • Get Your Club Gear
      Get Your Club Gear
    • Massive Choice on Lexus Parts
AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
kevinsgs300
Car Cleaning
17 posts in this topic
can anyone tell me how to clay a car please.
cheers kev.
only did it once , ,painstaking process , ,the "clay" is best described as a small lump of chewing gum ,
basically apply some spray lube onto the car then rub the small "clay" piece in circular motion over the paintwork ,
this removes tars & oxidants in preparation for applying a wax coat with good carnuba content
finally apply a sealant coat then relax for 6 months before doing it all again
or cheat like i do http://www.ebay.co.uk/itm/500mls-SHIMMER-PROFESSIONAL-CAR-POLISH-CARNAUBA-WAX-/300467715523?pt=UK_Car_Accessories_Car_Care_Cleaning&hash=item45f5457dc3#ht_1080wt_944
gives a great deep shine with very little effort
I find claying to be no harder than polishing or waxing your car. Just make sure you spray the lube liberally over the paintwork before rubbing the clay on, so that you don't mar the paintwork.
I used Meguiars Clay Kit and was pretty happy with the results. It comes with the lube spray and full set of instructions that are easy to follow.
Hi mate we have a 10% off code running and sell the clay bars you need, if you run out of lube the a heavily diluted meguiars shampoo is a spray bottle works just as well, and we do replacement clay bars on there own. Split the clay bar into 2. Make sure you warm it and soften it in your hands first, don't push to hard on the car the bar will do the work, polish and wax after, you won't believe the results.
Gary
as "lexi200sport" says apply lube liberally and as Gary Maxreflect" say don't lean hard just let the clay bar slip and slide over the surface. if the clay bar is sticking and catching on the paint then ur not using enough lube or ur leaning too hard. if u get a streak of clay on the paint its quite difficult to remove. You will hear and feel the clay bar catching contaminants an this should go smooth. keep lifting the bar up and you will see the contaminants on the bar continually fold these into the bar so that you are always using a fresh piece. also only clay after a good wash don't do it before washing. It works well at removing water marks from windows too.
Also, if you EVER drop the clay bay on the ground throw it away DO NOT TRY AND USE IT AGAIN (The only exception might be if you want keep it and use it on your wheels)
Did I mention if you drop it DON'T USE IT AGAIN??? !!!!
Excellent advice
If someone hasn't mentioned it before.....
Wash
Clay
Wash
Polish
Wax
Sit back pit on sunglasses go cruising and show it off
Lol perfect:) @ maxreflect
The meguiars clay bar kit is top quality and like the guys have said if you drop it through it away. I used it on my 300zx and it got rid of all the tiny particles that were embedded in the paintwork. Its a laborious job but well worth the effort for the final result.
you could use G3 cutting compound but its a really messy job and you risk burning the paint but as long as you keep the mop wet it should be OK.
My wife looked at me as if I was mad when i said I was going to 'clay the car'.
The result was unbelievable, as after the wash, clay, wax, wax and then wax, the shine and smoothness of the paintwork was unbelievable!
Whatever you do - clay that vehicle and enjoy the results!
I have clay, full kit of Autoglym products for washing, polishing, waxing(HD wax) sealer which are available if anyone wants to try them out on my car :driving:
cheers kev.
Well, did you ever clay your car?
Feedback much appreciated!
Also, how is everyone keeping their car spotless these days with the hosepipe ban? I haven't washed mine since the ban to be honest, and can't bring myself to take it to the commercial car wash, especially after seeing the lads using the same freakin brush to clean the wheels and the bodywork in one go :geek:
No hosepipe ban here, just floods!!
However, if there were, I'd have two choices, waterless car polish, eg showroom shine, or my karcher pressure washer fed from a water container.
You could have a water butt fed by your gutters, or apparently you could legally fill a bucket from the tap and use that to supply the pressure washer.
I've used the waterless polish and it's pretty good, very handy for my caravan too, though I doubt I'd risk it on a filthy car.
I would always choose waterless - esp in preference to using hard water. in fact a detailing spray from a clay bar kit used with a good clean microfibre cloth does much of what the same spray does with a clay bar, and with less risk of accidents.
I got the G3 Clay Mitt - Clayed car in about 45 mins - Way easier than the wee clay bars - Seems to do the same job.
Very impressed by the finish.
  • Recently Browsing   0 members
    No registered users viewing this page.
