Is200 Key
asadsaqlain
Hi everyone,
My is200 key has been damaged and i was wandering if i bought a off the market key from eBay which is an uncut blade and got it cut from a locksmith then i just put my immobilizer in it from
my original key will it work?
Thanks for any advice
Hi everyone,
My is200 key has been damaged and i was wandering if i bought a off the market key from ebay which is an uncut blade and got it cut from a locksmith then i just put my immobilizer in it from
If the damage is not to the electronics section you should be able to transplant the parts into a new blank key casing, they are fairly cheap on fleabay, I did this to a GS300 key fob although I did have to fit a bit of cardboard packing in as the buttons weren't flush but it does the job.
I also understand that there are 2 blade lengths so make sure you get the correct one when ordering.
