If I had a garage I would have done my own. The MK4 is a bit easier than previous models, so if you feel confident why not go for it? I don't think there's anything over complicated, it's just time consuming (and possibly back aching!)
  • 7 months later...
I will be attempting this on my MK4 very soon (failing at 225k miles)
I'm hoping to be able to remove the manifold and TB as one unit, I'm also hoping that I'll be able to use my double bendy ratchet spanners to remove the starter without taking off the rear water bypass. This should mean that the only gaskets I disturb are the 2 intake to cylinder head gaskets...which I will attempt to re-use!
Wish me luck
