Engine Rattle On Cold Start
Oldun
I have just joined the forum and would like some advice if possible. I hope this is the way to use the forum!
My 2005 Lexus GS300 with 56,000 miles (genuine)has occasionally a loud rattle on starting from cold. This may happen two or three times in a week and then vanish for quite a while. I have recorded the noise but my Lexus garage could not offer an explanation. I read that a member found that the torque converter drive plate was the problem and wonder how this was found out.
Thanks,
Oldun
Any clues as to where you think the noise is coming from eg clutch transmission engine?
Hi Steve,
I am certain it is coming from the engine compartment. If I start with door open whilst in garage I have stuck recorder under car and recorded noise. It really sounds like a bearing rattle and seems to last until oil pressure builds.
Hi Steve,
Could you leave your car with your Lexus dealer overnight so that they could start car from cold and get a good listen to it. Much easier to diagnose that way than just listening to a recording.
Hi Steve,
Hello Steve,
Thanks for the reply. I am afraid the noise only occurs at irregular intervals so I cannot say when it will next happen. Perhaps I had better wait until it happens everytime I start!!
There is a separate oil filter for the VVTI system which can clog and there deprive the cam adjustment system of oil
http://www.clublexus.com/forums/performance/401898-p1349-vvt-system-malfunction-bank-1b-blocked-oil-control-valve-filter.html
Very many thanks Steve. I will investigate further.
