Interior Lights
Not so sure you can swap the interior bulbs, well you can of course but if you swap the filiament bulbs for LEDs you will loose the fade out function.
Also be aware that you may get a "bulb failure" warning with exterior lamp swaps unless you make sure you have "loaded" LED bulbs.
