hello guys, im new to the forum. over the years ive owned 4 lexus's. 2 pre facelift ls 400's, a soarer t-t , and now a facelift ls 400 with vvti.
i have a problem with my ls 400 gps/radio unit. it works fine, but the audio settings knob does not work. i cannot adjust bass, mid, high, fader or balance. it is stuck to the front speakers only working, and because of the ill functioning knob, i cannot adjust the fader settings. this is irritating me as the sound system is great but only half of it is working ! anybody had this problem before? or know how to fix it?
not sure what model the radio is, its a touchscreeen gps/radio all in one from the factory. i pulled the fuses to try and reset the settings, it diddnt work, i removed the Battery lead, that diddnt work either. a quick fix would be nice :) everything works on the unit ,bar the audio adjustment knob.any help or comments greatly appreciated !
hi
sorry if this sounds too abvious - to toggle between the different setting i.e bass, treble etx you have to you press the knob it self - each time you press it a different setting will be highlighted - then you adjust it by turning the knob clock or anticlockwise depending on where you want the setting
hth
Tried that, I knew that, just wondering.if it could be an easy repair ? :)
I've used Autosounds on Scotswood Rd Newcastle and they were very obliging and reasonable. Now tell me you live in Berwick!!!
Hello from Finland, I have 98 LS400 and I have same problem. Last winter my audio and menu buttons stopped working. I have a command system too. I cannot even adjust my clock.. I have adjusted audio system via service menu. It would be great to get this problem fixed but I don´t know how...
Recently read about mapleaudio.co.uk ??? for LS audio issues ..... someone said that other car audio repair shops use this company.
