AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Sign in to follow this
lewis
Steering Wheel - In And Out Movement
Has anyone had problems with the In and Out movement of the steering wheel (Mk 4). Up and down works fine although the memory function does not work correctly, moves a little but not enough. Any Ideas ?
Try searching you tube, there was a link posted here a while back that had a you tube link to a video showing a repair.
I can't remember though whether it was up/down or in/out that had failed.
He has a grinding sound when operating. Video is
I have seen that video before, the problem I have is the in & Out movement not the up and down movement. There is no motor sound when I try to move the wheel in&out. Someone must have had this problem before and found a fix ? thanks guys
I have the same problem , and to date have not found a fix.
But i believe if hour looking to replace the motor the landcruiser are the same but alot cheaper, if you do find a fix let use know.
