Park Brake Adjustment
def_fid
I'm changing the rear discs on a 2006 Ls 430. The technical info says to back off the park brake adjusters anticlockwise. Mine, when viewed through the hole in the disc, appear to go up and down? Which way "backs off"?
Recently did this on my LS430, no need to back them off the disks will come off without any problems. You do however need to check them once the new ones are fitted.
HTH
Tc
