Where Is The Sat Nav Disc
It ejects from below the CD slot. Theres a plastic clear panel below the CD slot with a hole in either side of it. If you go into the Nav menu on the display and press eject CD it will come out. You MUST remove this plastic panel first, otherwise the disc will break it when it ejects. If you need a full procedure list, just ask and I'll take the manual out and get typing!!!
