jlj999
Remapping Ecu
Hi, I've just experienced the VSC /engine warning light on the car (GS300, 2005); After reading several posts and filling up with fuel the lights are off. Fault codes P0138 and P0158 (oxygen sensors were present). there looks to be differing stories about fuel caps, changing oxygen sensors and ECU's etc..all expensive and frightening - can the same be achieved by remapping the existing ECU?
Thoughts weclomed
I'm not aware of any Lexus ECU being reprogrammable, other than writing what the factory setup is. I'm think they have to be piggy backed or replaced with standalone ECU's.
Tightening the fuel cap is a free fix!
Replacing it will cost a lot lot less than letting Lexus dealerships swap out a perfectly good ECU and O2 sensors.
Ever since my one-time scare, I've not seen return of it since - so don't fret yourself into an early grave until you've seen to the above options first.
  • Similar Content
    • By Stephenlexusis220d
      Hi, I do not really have any idea about cars at all, upon starting my car this evening (lexus is220d ) 2007 I got the vsc error and turned on the engine and Tc lights. Would this be from a filter problem, I have had no problems before. It is due for a service in 2k (currently 80k)
      would you recommend to call the road side assistance and ask them to define the fault or to take it to a garage or a dealership and ask them to asses
      any help is much appreciated
    • By Yobosoku
      Hi, new to forum, there may be an already existing thread but I cannot find anything......ANYWHERE! I need an ecu pinout for a 2001 is200 using a 1gfe with an ecu number 89661-53200. I need this pinout diagram and expertese to fit a bee*r limiter basically because I want one and I like being a loon in my car. There are people who hate/disagree with them, however I would like one in my car and I would appreciate help fitting it.
      any help appreciated.
    • By mep
      Hi everyone. It's not Xmas but might as well be.
      I had a problem with a worn rear wheel bearing. The car had been used to tow around an exhibition trailer in its early life and at 175,000 miles started to complain. I'm not complaining as 175K miles is still good value. To look at car is immaculate inside and out. Still gives 40MPG and I am still in love with car after 7 years of ownership.
      Changing the bearing I managed to damage the ABS sensor: and when trying to remove the broken sensor, I damaged the sensor ring. To make matters worse, thinking I could repair the ring, I removed the sensor ring.
      Duh! What was I thinking.
      The friend, whose garage I was using to do the work, suddenly needed his garage and so I had to move. I drove the car home and parked up.  On the way home. No Speedo. P/S Red light on even though power steering feels okay.  ABS light on. Engine light on. VSC complaining.
      So now I have a replacement hub, with ring, new ABS sensor fitted and all on the car.
      But all the lights still on.    I have tried removing the battery over night.  All lights still on except Engine light.
      Any one with any thoughts before I troll off to my Lexus dealer who will want more money than they value the car at to plug in their OBD reader.
    • By Rusty Crobar
      My dash lit up like a Christmas tree yesterday while on the motorway. Traction control was disabled, check VSC & CEL were on and I was understandably worried!
      There is a lot of info from lexus owners about the vsc light but nothing relating to the isf. Apparently it covers a range of issues from loose fuel cap to broken ecu's 😯. It seems like most issues aren't actually related to the engine or the traction control system!
      Got the car to my friendly mechanic for a diagnostic and it turns out it's the oxygen sensors for the cats. There was no voltage going to either of them so he suspects it's a broken wire rather than the sensors themselves. Going back on Wednesday to get it fixed.
      Not really a suprise as the bottom of the car was rubbing on the track so much 😳
      This is purely down to how low and soft my coilovers are,  shouldn't put anyone else of track days 🖒
