Need some help desperatly with my master key for my 2003 Lexus Is200.
I turned the key while it was in the ignition and the plastic casing snapped! heard this is a common problem though. The actual blade is fine and so is the remote but its just the casing that has fallen to bits.
So my question is, can I just buy the plastic case off eBay and fit the blade and the transmitter ? or is it a bit more complicated than that?
Any thoughts from people who have had the same/similar problem would be much appreciated.
Many Thanks
My car came with three keys; the grey valet key, a black master key (with casing cracked, but glued) and another master key completely broken apart.
I bought a flip key replacement, local key cutter cut mine, and although I had a little problem with it at first (wouldn't turn in ignition) a quick run over with a metal file soon sorted that. Been working fine for the past 3/4 months
I also bought one of these - http://www.ebay.co.uk/itm/Lexus-Toyota-Remote-3-button-key-fob-denso-type-is200-is300-gs200-gs300-LS-/251177034300?pt=UK_Car_Accessories_Safety_Security&hash=item3a7b51623c
Just as a spare, since you don't often see them with the logo on the back. Quality is nice, buttons fit perfectly, etc. Not had it cut yet, it's just there as a spare.
