Abs Light And Vsc Light
woody86
Hi all. My is250 has a little problem. The abs and VSC light keeps coming on. But when I leave the car off for for a time it's fine. But then it will just come on at random times. Thinking it might be a loose connection to s sensor in one of the hubs. Has anyone had a similar problem?
Abs should be linked to the vehicle stability control. One or more of your abs sensor is malfunctioning. It usually starts off being intermittent then the magnetic sensor fails permanently. The car's computer will have recorded, needs plugging in to diagnostic kit. Connector above the pedals behind the plastic cover.
